Extend the platform,
empower your team.
This extension enables a dashboard for the self-monitoring environment on the Managed cluster showing cluster utilization and data ingest.
Extension by DynatraceThis extension enables a dashboard for the self-monitoring environment on the Managed cluster showing cluster utilization and data ingest on cluster.
This is intended for users, who:
This enables you to:
Compatibility Requirements
This dashboard was built for Dynatrace Managed clusters to be used in the self-monitoring environment of the cluster. Although it can be used in other environments (Managed and SaaS), some of the data shown may be inaccurate for these.
The dashboard shows aggregated data for the environments in your managed cluster. It gives you an impression of the current utilization of your cluster and whether your cluster is still properly sized to cope with the current load.
This dashboard provides
Simply activate the extension in your Dynatrace managed self-monitoring environment using in-product Hub. For further information about the self-monitoring environment see the Dynatrace help page Local self-monitoring environment.
Minor Bug Fixes:
Added contributors utilization to dashboard: new tile shows a break down of the cluster utilization by individual contributor.
Minor bug fixes:
New feature:
Minor bug fixes:
No release notes
First version of the Dynatrace Self-Monitoring extension installing a self-monitoring dashboard for Dynatrace Managed.
