Extend the platform,
empower your team.
Extend Dynatrace with custom ingest APIs.
Technology by DynatraceWhenever you have a monitoring use case that is not covered by Dynatrace OneAgent or Dynatrace Extensions you still have the possibility to use our APIs to get your data into Dynatrace.
This could be helpful in the following scenarios
We have API endpoints for custom logs, metrics and events ingest. Below you find the link to the section in our API documentation.
Custom log ingest https://www.dynatrace.com/support/help/dynatrace-api/environment-api/log-monitoring-v2/post-ingest-logs
Custom metric ingest https://www.dynatrace.com/support/help/dynatrace-api/environment-api/metric-v2/post-ingest-metrics
Custom event ingest https://www.dynatrace.com/support/help/dynatrace-api/environment-api/events-v2/post-event
