ActiveGate extension to monitor your Control-M jobs execution status.
Monitor the status of your Control-M Jobs.
For each job that ends in “Ended Not OK", an event is sent to Dynatrace with the details:
Each Control-M monitored will consume ~4204.8 DDUs/year
/automation-api/run/jobs/status
reachable.unzip -o -d /opt/dynatrace/remotepluginmodule/plugin_deployment Filecustom.remote.python.controlm.zip
/opt/dynatrace
Settings > Monitored technologies > Custom extensions > Upload extension
Create an endpoint for each cluster you would like to monitor. This is done in `Settings > Monitored technologies > Custom extensions > ControlM.
The parameters are:
https://<IP_or_HOSTNAME>:8443
The logs under %PROGRAMDATA%
(windows) or /var/lib
(linux) give us more details in case of failures
The full path is /var/lib/dynatrace/remotepluginmodule/log/remoteplugin/custom.remote.python.controlm/ControlMPlugin.log
or
C:\ProgramData\dynatrace\remotepluginmodule\log\remoteplugin\custom.remote.python.controlm/ControlMPlugin.log
