Intelligent end-to-end observability for serverless and hybrid environments using Azure Functions.
Monitor the health of your distributed applications using serverless functions. Reduce mean-time-to-repair (MTTR) and optimize your serverless workloads. Dynatrace automatically analyzes Azure Functions, detects and diagnoses problems in real-time with DAVIS AI engine, and pinpoints the root cause before your customers are even affected.
If your Azure Function is hosted on Consumption- or Premium plan, see instructions to enable tracing.
If your Azure Function is hosted on AppService Plan, see instructions to enable tracing.
To capture Azure Function service metrics, enable Azure Monitor Integration.
To ingest logs for Azure Functions, enable Azure Log-Forwarding.
