Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Apache TomEEApache TomEE
Apache TomEE
Apache TomEE
Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed anywhere in your stack.
Technology
Free trial
  • Product information
Overview
Dynatrace automatically detects all applications and microservices deployed in your application server and provides automatic end-to-end tracing, application server metrics and log insights. Dynatrace visualizes your web application and its dependencies from website to application to container, infrastructure and cloud. It diagnoses anomalies in real-time with AI and pinpoints the root-cause down to the broken code before your customers are even affected. Deep code-level insights combined with market-leading profiling capabilities like method hotspots, error/exception analysis, memory profiling, and thread analysis will help you leverage the robustness of your production environment.
Use cases
  • Capture every transaction, across every tier, without gaps or blind spots.
  • Understand all dependencies of your applications including all database statements executed and their performance.
  • Improve the performance of your Java code with continuous insights into your applications.
  • Profile CPU, memory and thread problems with Dynatrace' industry leading production grade continous profiler.
  • Detect availability and performance problems across your stack proactively.
  • Monitor all your application metrics via Dynatrace's builtin JMX monitoring capability.
  • Leverage open observability frameworks like OpenTelemetry or Micrometer to add custom metrics and custom traces instrumentation.
Get started
If your Apache TomEE is running on a virtual machine directly, install OneAgent on that virtual machine to get started.
If your Apache TomEE is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your Apache TomEE is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate log monitoring to get full log insight.
Dynatrace
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Apache TomEE
Tomcat (JMX) logo
Tomcat (JMX)
JMX monitoring of Tomcat connection and thread pools, and web request activity.
Apache Tomcat logo
Apache Tomcat
Dynatrace Hub
Hub HomeGet data into DynatraceBuild your own app
Dynatrace Intelligence - Agentic Operations SystemAgentic AI ecosystem
Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
All
0 Results filtered by:
Default empty state
We couldn't find any results
You can search all listings, or try a different spelling or keyword. Still nothing? Dynatrace makes it easy to create custom apps.
Find a partnerLearn to build apps
