Extend the platform,
empower your team.
Automatically and intelligently monitor, analyze and optimize your applications based on Apache OpenEJB.
Technology by DynatraceWith Dynatrace you will get observability for all applications developed with Apache OpenEJB including end-to-end tracing, metrics and log insights. Dynatrace will automatically detect services for your remotely called entrypoints (via RMI, web requests, queues, etc.) Additionally Dynatrace deep code level insights will give you CPU profiling insights including method hotspots, memory and thread profiling, insights into database calls, error/exception analysis, and much more. Comprehensive out-of-the box metrics will give you insights into memory allocation, garbage collection, and thread behaviour.
If your web app is running on a virtual machine directly, install OneAgent on that virtual machine to get started.
If your web app container is running as a workload in Kubernetes, set up Dynatrace on Kubernetes.
If your web app container is running as a workload in OpenShift, set up Dynatrace on OpenShift.
Activate log monitoring to get full log insight.
The simplest way to capture all observation signals automatically and in context.
Automatically and intelligently monitor, analyze, and optimize your application server and all applications deployed anywhere in your stack.
Automatic and intelligent end-to-end observability for Java applications.
