Spring Framework performance monitoring
Performance monitoring and capacity management for Spring Framework applications
What is the Spring Framework?
The Spring Framework is an application framework and inversion of control container for the Java platform. The framework's core features can be used by any Java application, but there are extensions for building web applications on top of the Java EE platform.
Dynatrace monitors and analyzes the activity of your Spring Framework applications, providing visibility down to individual database statements.
  • Visualize service requests end-to-end in your Spring apps
    Dynatrace detects your applications’ transactions from end-to-end and shows the actual execution of each service through our Service flow.
  • Get CPU hotspot analysis for background threads
    Dynatrace shows you where your Spring applications consume CPU in background threads, schedulers, or other proprietary services.
  • Understand the impact of issues on customer experience
    While monitoring your Spring Framework apps, Dynatrace learns the details of your entire application architecture automatically.
Gain visibility into your Spring applications
Dynatrace monitors and analyzes the database activities of your Spring applications, providing you with visibility all the way down to individual SQL and NoSQL statements. Just a few of the performance metrics you will see on your Dynatrace dashboard:
  • JVM metrics
  • Custom JMX metrics
  • Garbage collection metrics
  • All database statements
  • All requests
  • Suspension rate
  • All dependencies
In under five minutes the Dynatrace OneAgent automatically discovers your entire Spring application.
Start monitoring your Spring Framework in under 5 minutes!
In under five minutes, Dynatrace shows you CPU, memory, and network health metrics all the way down to the process level.
  • Manual configuration of your monitoring setup is no longer necessary.
  • Auto-detection starts monitoring new virtual machines as they are deployed.
  • Dynatrace is the only solution that shows you process-specific network metrics.
Dynatrace understands your applications’ transactions from end-to-end. Service flow shows the actual execution of each individual service and service-request type. While Smartscape shows you your overall environment topology, Service flow provides you with the view point of a single service or service-request type.
While monitoring your Spring applications, Dynatrace learns the details of your entire application architecture automatically.
  • Artificial intelligence automatically identifies the dependencies within your environment.
  • Dynatrace detects and analyzes availability and performance problems across your entire technology stack.
  • By making root cause analysis, Dynatrace visualizes how problems evolve and how they impact the user experience.
Full wave bg
Dynatrace gave us a single source of business truth that allowed us to monitor customer experience across all channels of engagement, including web, mobile and online check-in services.
Haluk Yüzücü Infrastructure & Operations Manager, Pegasus
Start monitoring your Spring apps with Dynatrace!
You’ll be up and running in under 5 minutes:
Sign up, deploy our agent and get unmatched insights out-of-the-box.
Dynatrace Free Trial
Organizations transforming with Dynatrace
See customer stories
